Datalog to CX9000
Begonnen von Morten Aasted, 31. Mai 2011, 12:06:14
Morten Aasted
Hi All
Is it possible to log to the internal memory in a CX9000 with the DLOG_STORE_FILE_CSV?
Or is there at better way of storing a few datapoints with timestamp in a file?
Regards
Morten
DLOG_STORE_FILE_CSV ?
you can write logdata in a file
The demo programs are in network.lib in the folder "DEMO" included. If
they are used, the needed programs should be copied to your project and
then can be adjusted to your needs. Some modules require the disclosure
of its own specifc parameters so that they are fully functional.
Morten Aasted
Hi peewit
Okay, so if you remove the d:\ part in the filename it will save in the flashmemory as *.csv?
example:
'test.csv' is stored in the default directory on the plc
