Oscat and 64-bit controllers
Begonnen von AntonZan, 11. August 2025, 11:08:39
AntonZan
I have been using the Oscat libraries BASIC and NETWORK for several years now and have always been happy with the added functionality. Recently, we have started looking into 64-bit controllers at work, programmed through CoDeSys 3.5 with 64-bit targets. Here is where I run into some issues. It seems more people have asked about this every once in a while. So far I find no consensus on how things with Oscat will progress in that direction.
My question is: will any work be done about supporting 64-bit targets for the OSCAT libraries? Either by the good people of the original Oscat libs here, or some small group of volunteers? If so, how are we to move forward on this?
AntonZan
#1
I have done some work on a few things that are most urgent for me. However I lack time and resources to do everything and have it properly reviewed and tested by others. What I have found and what I have done so far can be useful additional background information.
AntonZan
#2
OSCAT_BASIC
Mostly works fine on either 32bit or 64bit controllers. However, the POUs _BUFFER_CLEAR() and _BUFFER_INIT() have their code very specifically optimized for 32-bit alignment. They would need to be either simplified or completely rewritten to run on 64-bit controllers. Even then, I would very much prefer to have a version that can be used without modifications on both 32-bit and 64-bit targets. I'm thinking use of some combination of pragma's, SIZEOF(), types like __XWORD and __XINT.
I currently don't have time to rewrite myself, so as a workaround I have made a copy of the BASIC library where I excluded _BUFFER_CLEAR() and _BUFFER_INIT(). I actually used these in one or two places. For now I have gone back to the use of simple FOR loops instead. It works fine, although I have lost the optimizations of the original OSCAT POUs.
AntonZan
#3
OSCAT_NETWORK
On CoDeSys the original implementation of network and file access depends, among other things, on two libraries SysSocket23 and SysFile23. Both of these exist only for 32-bit platforms. Their counterparts SysSocket and SysFile will work on both 32 bit and 64 bit. They have similar functionality but types used and interfaces to the relevant POUs are not identical. Substantial changes seem required for POUs IP_CONTROL(), IP_CONTROL2() and FILE_SERVER().
So far we do not make extensive use of specific networking POUs. Everything that uses IP_CONTROL() and IP_CONTROL2() is for now commented out in my copy of OSCAT_NETWORK. We do use the DLOG POUs and types. So I have adapted the FILE_SERVER() function block to use SysFile rather than SysFile23. It is no rocket science, but not trivial either. So far it works for me, but lack of time may have resulted in me missing some points and taking some shortcuts. I have made extensive use of the __XWORD type. This allows for code that will run on both 32-bit and 64-bit platforms. File handles and error handling have needed some changes. It is not ideal, it does work.
As we do most logging to the file system, I did convert the POUs for that (mostly DLOG_STORE_FILE_CSV). Parts of the DLOG ecosystem that log via a network connection of the controllers would require IP_CONTROL() and IP_CONTROL2() to be reworked. I don't have time for that. For now I have excluded those parts from build in my copy of the OSCAT_NETWORK library.
