oscat.lib => oscat.lib fuer TwinCAT/CoDeSys => Thema gestartet von: drChiavo am 05. Februar 2016, 14:29:18
Hello,
What I want to do is increment a value by 1 each second and I was trying to use the linear ramp "FT_RMP" but unfourtunately is not working.
This is what I wrote
rampFunction(rmp := TRUE, in := 1, KR := 1, KF := 1, out => , busy =>, UD => );
IF rampFunction.UD THEN
increasePressureValue := increasePressureValue+1;
END_IF
Does anyone could tell me if the code is wrong or why is not working ?
Thanks
i think ramp has nothing todo:
source(in) = 1, dest = 1, so what is todo ?
But i am not sure...
I would yose a simple ton for this:
fbTon(in:= not fbTon.q, PT := t#1s);
if fbTon.q then
# 1 second is over
end_if
hth
Shrimps
Hello Shrimps,
Thanks for your answer. I tried what you told me but after the second 3 starts to sum up random numbers. Here is the code.
WHILE increasePressureValue <= 600000 DO
myTimer(IN := NOT myTimer.Q, PT := T#1S);
IF myTimer.Q THEN
increasePressureValue := increasePressureValue + 10000;
END_IF
END_WHILE
Any idea about the error?
Thanks
first you made the worst case of wrong use of Systemtimers like ton, tof tp:
They have to be called cyclic and not on demand !
Please catch the mytime at first statement so it will be called every cycle !
Then your WHILE would do (i hope) better things...
Another idea:
if increasePressureValue <= 600000 and myTimer.Q then
end_if
One of many Solutions for your way 8)
Hope that helps
Regards
Shrimps
PS: It looks you are comming from PC-Programming ?
Hello Shrimps,
I have tried what you told me but still the same problem. After the second 3 , "increasePressureValue" gets randoms numbers... I don't know what the problem is :/
Yes, I´m a beginner with CoDeSys. :P I have started to program two weeks ago...
Regards,
drChiavo
Hmm,
drives me crazy:
Which IDE do you use (please full qualified)
Show me the full source !
Heres my example which works fine:
PROGRAM MAIN
myTimer: TON;
increasePressureValue: DINT;
myTimer(IN := NOT myTimer.Q, PT := T#1s);
IF increasePressureValue <= 600000 AND myTimer.Q THEN
END_IF
END_PROGRAM
Regards
Shrimps
Hello Shrimps,
I don't know what I was doing wrong but now it is working!
Thanks a lot for your help :D
Regards,
drChiavo
Sounds very good...
So waiting for the next :)
