Autor Thema: REAL_TO_FRAC - Algorithmus in eine Dezimalzahl in einen Bruch umzuwandeln  (Gelesen 11255 mal)
cleber.ruiz
Hello community OSCAT.
I found a algorithm at http://homepage.smc.edu/kennedy_john/DEC2FRAC.PDF which can be used to convert any decimal number in a fraction.
I needed this solution, because I use MOVIDRIVE from SEW-EURODRIVE to control aplications such as Flying Saw to cut materials during synchronized moviment.
The problem is that the ratio between master and slave must be adjusted in two variables or parameters of Movidrive named GFMaster and GFSlave which works as a fraction.
With this algorithm I rewrote a function block below that cam be used for this purpose.
I made some tests with it running in MoviPLC model DEH41B from SEW and worked very well.
I would be grateful if this function can be added in the next revision of the library Oscat.lib
FUNCTION_BLOCK REAL_TO_FRAC
   Decimal: REAL;
   AccuracyFactor: REAL := 5.E-007;
VAR_OUTPUT
   Numerator: DINT;
   Denominator: DINT;
   DecimalSign : REAL;
   Z : REAL;
   PreviousDenominator : REAL;
   ScratchValue : REAL;
   FractionNumerator: REAL;
   FractionDenominator: REAL;
IF Decimal < 0.0 THEN
   DecimalSign := -1.0;
   ELSE DecimalSign := 1.0;
END_IF
Decimal := ABS (Decimal);
IF Decimal=D_TRUNC(Decimal) THEN (*handles exact integers including 0*)
   FractionNumerator := Decimal*DecimalSign;
   FractionDenominator := 1.0;
   RETURN; (*EXIT;*)
IF (Decimal < 1.0E-19) THEN (*X = 0 already taken care of *)
   FractionNumerator := DecimalSign;
   FractionDenominator := 9999999999999999999.0;
   RETURN;
IF (Decimal > 1.0E19) THEN
   FractionNumerator := 9999999999999999999.0*DecimalSign;
   RETURN;
Z := Decimal;
PreviousDenominator := 0.0;
REPEAT
   Z := 1.0 / ( Z - D_TRUNC( Z ) );
   ScratchValue := FractionDenominator;
   FractionDenominator := FractionDenominator*D_TRUNC(Z)+PreviousDenominator;
   PreviousDenominator := ScratchValue;
   FractionNumerator :=D_TRUNC(Decimal*FractionDenominator + 0.5); (* Rounding Function *)
UNTIL (ABS((Decimal-(FractionNumerator/FractionDenominator))) < AccuracyFactor) OR (Z = D_TRUNC(Z))
END_REPEAT;
FractionNumerator := DecimalSign*FractionNumerator;
(*These last lines where used only to convert the output variables in double integer*)
Numerator := REAL_TO_DINT(FractionNumerator);
Denominator:= REAL_TO_DINT(FractionDenominator);
Re:REAL_TO_FRAC - Algorithmus in eine Dezimalzahl in einen Bruch umzuwandeln
« Antwort #1 am: 19. November 2010, 08:27:04 »
thank you, that we do
cleber.ruiz
« Antwort #2 am: 22. November 2010, 03:00:24 »
Correction:
I made a mistake when I wrote the last lines in this code.
To this function block be able to calculate fractions of integers numbers including the zero. Is also necessary to put that last lines in other parts of the code.
Following, you can have the revised code and also download the export file of it.
Sorry for my falure.
   Decimal: REAL;
VAR_OUTPUT
   Numerator: DINT;
   Denominator: DINT;
   DecimalSign : REAL;
   Z : REAL;
   RETURN;
   RETURN;
   RETURN;
Z := Decimal;
REPEAT
END_REPEAT;
« Letzte Änderung: 22. November 2010, 03:02:53 von cleber.ruiz »
