Autor Thema: Heating start time  (Gelesen 7192 mal)
Offline david
Heating start time
« am: 25. November 2011, 20:03:43 »
I want to have at 7h in the morning a temperature of 21°. At night, the heating only switches on when it is colder than 16°. Does anyone have an idea how to calculate the optimal start time for the heating? This is to have exactly 21° at 7h.The goal is not to have cold in the morning and also not to start to early with heating and wasting energy.
Thanks.
Offline kenzo
Re: Heating start time
« Antwort #1 am: 26. November 2011, 08:25:36 »
This depends on so many variables which are only known to you that I believe it's impossible to provide you with answers.
- what's the flow temperature? Do you want to change that as well?
- what kind of house is it? (stone/wood/etc.)
- how big is the house?
etc.
My approach would be to simply test it - try start heating at 6am, when do you finally reach 21°C?
Plus, does it make sense to go to 16°C at all?
Offline shooter
  • Shooting Fuzzy temperatures
    • ICQ Messenger - 60155180
« Antwort #2 am: 14. Dezember 2011, 13:57:37 »
There is a block for this, the essence of it, is measure the real temp at 6 oclock. If the temp is 16 and your slope is 5 degrees/hour start heating now.
If temp is 17 start heating at 4/5 so about 6:15 etc.
As the slope must be measured just start at 6 and check when 21 is reached. this will be your slope.
remember to set max watertemp on the boiler as this will influence the time cosiderate.
