Autor Thema: HX calculator  (Gelesen 9582 mal)
Offline Vinnie_VdB
HX calculator
« am: 05. Juli 2012, 18:24:01 »
Hello people, I am able to read German but just can't write it. I am a user of SoMachine software for both Schneider M268 and M258 PLC's. More and more do I start using them for HVAC solutions and found already a few FB's for calculating Enthalpy but what would really help is a HX calculator.
Oscat in general was a revelation when I was told about this extensive library but like written above could an HX FB really be a worthy add-on to any upcoming release.
It's a FB that has basically 3 inputs
- dry bulb temperature (regular air temperature in °C) with accuracy of 0.1°C
- % relative humidity ranging from 0 to 100% with accuracy of 0.1%RH
- atmospheric pressure in Pascal (Pa)
And then 3 outputs:
- Absolute humidity in grams/kilo air with accuracy of 0.1g/kg
- Enthalpy in kcal/kg air with an accuracy of 0.001 kcal/kg
- DewPoint temperature in °C
As this is regular HVAC is the input temperature never going to be anywhere between -50.0°C and +50.0°C (and so will the dew temperature)
Attached to this post is an Excel document that is showing the calculations to reach the 3 output results.
Sorry for writing this in English but German is not an option as this would be for all of us unreadable ;).
Thank you and keep up the good work.
Should anyone however is able to put this in a FB separately it would be much appreciated.
Offline Vinnie_VdB
Re: HX calculator
« Antwort #1 am: 06. Juli 2012, 00:36:15 »
Can a moderator please move this post to "oscat.lib für CoDeSys 3"?
Thank you already.
Offline shooter
  • Shooting Fuzzy temperatures
    • ICQ Messenger - 60155180
Re: HX calculator
« Antwort #2 am: 12. Dezember 2012, 20:34:33 »
If you are still interested, please write here or send me an email, i do have the routine written.
