Autor Thema: Siemens awl convertion to codesys v2  (Gelesen 6761 mal)
Offline Jaco84
« am: 12. August 2016, 08:18:52 »
Guten Tag Herren
Ich habe Download die Oscat Bibliothek konvertieren Siemens Ahle auf Codesys IEC v2.3.I haben versucht, die Anwendung ohne Erfolg. Du kannst bitte beraten, wie Sie dies tun.
Ich habe Moeller Eaton erleben wenn jemand Rat braucht oder??
Früher habe ich konvertieren ins Deutsche zu übersetzen.
Offline Jaco84
Re: Siemens awl convertion to codesys v2
« Antwort #1 am: 12. August 2016, 08:20:05 »
my email jacojunior84@gmail.com
Offline mattsches
  • Sr. Member
« Antwort #2 am: 18. August 2016, 11:39:53 »
Hello,
we might be better off using English, since the (automated?) translation to German is quite hard to read.
I understand that you want to use the OSCAT libraries on a Moeller Eaton PLC running Codesys 2.3, and that you tried to convert the Siemens library to Codesys.
If that is correct, I recommend to use the OSCAT libraries for Codesys 2.3 directly that can be downloaded from the download page (next to the S7, PCWORX and Codesys 3.5 versions). OSCAT basic for Codesys 2.3, for example, can be found here: http://www.oscat.de/component/jdownloads/summary/2-oscat-basic/3-oscat-basic-333.html
Regards,
Offline Jaco84
« Antwort #3 am: 18. August 2016, 23:11:48 »
I managed to get that part.Thank you.Is there any way that I can convert the AWl files of any siemens project to use it in Codesys?
Thank you in advance
