Autor Thema: DLOG_STORE_FILE_XML  (Gelesen 5289 mal)
Offline radreg41
DLOG_STORE_FILE_XML
« am: 21. Juni 2018, 23:55:00 »
Hi Peewit,
Greetings From Houston.
I have recently joined this forum and i glad that i found this forum.
As for my project, i am using ABB Codesys version 2.3.9 with PM573-Eth PLC. I have added your Oscat basic 333 and Network Lib_130. Also, i am using the demo program on the libray " DLOG_Store_File_XML". I loaded the project and i got an error as ERROR_C=1 & ERROR_T AS 1. Also, it is not saving the xml file on the path.
My questions are:
1. What should be the path address--- is it the path to the Plc internal address (ramdisk, userdisk?) or is it the path of the C drive of my computer?
2. Is this library compatible with ABB PLC? is it strictly platform dependent to Wago and TWIN cat?
3. DO i need to adjust the settings to be able to work on other vendor PLC's like ABB?
4. Right now, i have save the FTP addess as 21? Does it needs to be other value?
5. What does the ERROR_C=1 and Error_T referring to?
6. Do i need to change the Library version?
I will really appreciate your feedback.
Du hast einen schönen Tag
Thanks
Rad
Offline radreg41
Re: DLOG_STORE_FILE_XML
« Antwort #1 am: 26. Juni 2018, 15:24:42 »
Thank You so much for the feedback, Peewit!
