Autor Thema: NET_VAR_CONTROL Multiple Clients  (Gelesen 6896 mal)
Offline Bill McCormick
« am: 28. Juni 2018, 22:00:25 »
Sorry for assuming someone can help me in English, but I don't have Duetsch, and I would rather not have some broken translator mess up my question.
My OSCAT NET_VAR_CONTROL question is if it is possible for multiple NET_VAR_CONTROL clients to connect and share data with a single NET_VAR_CONTROL server? Or would I need to have a NET_VAR_CONTROL server for each client?
Thanks,
Bill
Re: NET_VAR_CONTROL Multiple Clients
« Antwort #1 am: 28. Juni 2018, 22:18:23 »
hello
No, you can't do that.
I didn't plan it at the time.
you must use multiple NET_VAR_CONTROL server instances with different port numbers
« Antwort #2 am: 28. Juni 2018, 22:36:40 »
Thanks for the speedy reply!  :)
Do you have any insight as to how difficult that might be to do (single server instance?) and if it would be a worthwhile project (many would find useful?)
« Antwort #3 am: 29. Juni 2018, 07:12:35 »
hi
The oscat_network is designed to work on as many platforms as possible in the same way
As a result, the functionblock IP_CONTROL is not designed for
This would require a complete design change
