Autor Thema: IP_CONTROL 16#00FF0000  (Gelesen 9783 mal)
tomtomgooo
« am: 11. Oktober 2014, 13:37:52 »
Hello,
I'am a french oscat's user and i have a little problem with network.lib.
In all my test i have this error 16#00FF0000
I have codesys 2.3.9.25 and wago 750-841
network.lib is 121hf1
I have attached an scree print for understand
Re: IP_CONTROL 16#00FF0000
« Antwort #1 am: 11. Oktober 2014, 17:31:05 »
hi
error code : 00ff0000 = data send error
have you in the sps-control a valid gateway address and subnetmask set ?
latest network lib (v1.30)
tomtomgooo
« Antwort #2 am: 11. Oktober 2014, 18:53:35 »
Thank you for your answer,
I have rightly configurate the wago ( I can send and receive on http_get(wago) in an another program )
I have try with the 1.30 version, it is the same result.
I have sniffed with wireshark and I can see that nothing in sended between wago and gateway
Thx for your help
« Letzte Änderung: 11. Oktober 2014, 20:42:06 von tomtomgooo »
« Antwort #3 am: 11. Oktober 2014, 22:48:08 »
in the network-library in the folder "demo" are demo programs
you can try it
do you use a very old firmware?
tomtomgooo
« Antwort #4 am: 11. Oktober 2014, 22:56:06 »
I have tried dns_rev_demo, and it is the same result, always timeout.
I'am with    Firmware revision    01.11.01 (09)
Is it too old?
« Antwort #5 am: 12. Oktober 2014, 07:04:47 »
Is it too old?
may be
the library works normally without any problems on the 750-841
-> get the latest firmware from wago support
tomtomgooo
« Antwort #6 am: 15. Oktober 2014, 07:42:54 »
Thanks for help, with firmware 21 all is now ok.
Merci  :)
