Autor Thema: ONTIME TIA V13 S7-1517F  (Gelesen 7705 mal)
Offline wim.cranen@wccandm.nl
« am: 01. Juli 2015, 16:11:08 »
Guten Tag, die Damen und Herren.
Good day, ladies and gentlemen.
Wer hat der Baustein ONTIME schon verwendet unter TIA Portal V13, auf eine SPS S7-1517F?
Frage: funtioniert der Baustein?
Wo has used the ONTIME block under TIA Portal V13, on a PLC S7-1517F?
Q: are the results ok?
Greetz, Wim.
Offline shrimps
Re: ONTIME TIA V13 S7-1517F
« Antwort #1 am: 02. Juli 2015, 14:13:06 »
Hello,
i am using Ontime in Twincat(Codesys) for about 3 Months and it works fine.
Sorry, no Siemens...
Regards
Shrimps
Offline mg
« Antwort #2 am: 07. Juli 2015, 14:38:34 »
On 1511 and 1513 it works.
But I have a Problem when I make a firmware-update or complete Download.
All my hours are away.
So as long you do not reset you PLC it works fine.
Take attention at: www.oscat.de/community/index.php/topic,2244.0.html when you have other PLC's (eg. 300)
Mg
« Letzte Änderung: 07. Juli 2015, 14:41:27 von mg »
« Antwort #3 am: 08. Juli 2015, 09:37:08 »
Thanks,
I've tested ONTIME and T_PLC_MS on a S7-1517F and they are ok.
Before firmware update, always make a backup of the system to save actual values.
And indeed, if you do a complete download, all your memory wil be reset to default.
Greetz, Wim.
