Autor Thema: TONOFP2  (Gelesen 16176 mal)
Offline stlfx
TONOFP2
« am: 24. September 2015, 13:06:19 »
Hallo!
This is my first post here. I wrote this function, may be somebody interested.
TONOFP2 generated a T_ON Delay on start pulse, and T_OFF Delay after end of pulses on Input IN.
Best regards,
MJ
FUNCTION_BLOCK TONOFP2
TITLE = 'TONOFP2'
//TONOFP2 generated a T_ON Delay on start pulse, and T_OFF Delay after end of pulses on Input IN
VERSION : '0.1'
AUTHOR  : MJ
FAMILY  : M
  IN : BOOL;
  PAUSE : BOOL;
  RESET : BOOL;
  T_ON, T_OFF : TIME;
  Q : BOOL;
  TON_ON : TON;
  TON_OFF : TON;
  T_ON_REMAINING, T_OFF_REMAINING : TIME;
  init: BOOL;
  lastpause: BOOL;
  pulse: BOOL;
BEGIN
IF RESET THEN
  TON_ON(IN := FALSE, PT := T_ON);
  TON_OFF(IN := FALSE, PT := T_OFF);
  init := FALSE;
  Q := FALSE;
  IF IN AND NOT pulse THEN
    T_OFF_REMAINING := T_OFF;
    IF NOT init THEN
      init := TRUE;
    T_ON_REMAINING := T_ON;
  pulse := IN;
  IF init AND NOT PAUSE THEN
    TON_ON(IN := TRUE);
    TON_OFF(IN := TRUE);
  IF TON_ON.Q THEN
    Q := TRUE;
  IF TON_OFF.Q THEN
    Q := FALSE;
    init := FALSE;
  IF init THEN
    IF PAUSE AND NOT lastpause THEN
      T_ON_REMAINING := T_ON_REMAINING - TON_ON.ET;
      TON_ON(IN := FALSE, PT := T_ON_REMAINING);
      T_OFF_REMAINING := T_OFF_REMAINING - TON_OFF.ET;
      TON_OFF(IN := FALSE, PT := T_OFF_REMAINING);
  lastpause := PAUSE;
END_FUNCTION_BLOCK
